跳转到主内容
Repair guides for machines designed to move slowly and get big jobs done, including farm vehicles and construction vehicles designed for specialty tasks.
83 个问题 查看全部
How to prime aperkins diesel
describe the steps to prime fuel system?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Mine has hand pump have got fuel coming out I thinking have a wiring problem need all help I can get thankyou
完成的
@edthehead what model is your Perkins? What are the issues with it?
完成的
添加一条评论
2个答案
已选择的解决方案
Does it have an electric or mechanical fuel pump? Electric or mechanical injectors? The old school way was to loosen the fittings on the injectors to bleed the air out. Crank the engine over till fuel flows. Once fuel flows out all 4, 6, or 8 fuel tubes you tighten the fittings and clean up. Then it should be ready to go. Electric pumps, if they are even used, are much easier to prime. Turn the key on and the pump will run till it builds pressure then shuts off. Turn off the key and SLOWLY and CAREFULLY open the fitting to bleed off the air at each injector or at the end of the fuel supply tube.
这个答案有帮助吗?
得分 0
添加一条评论
Thank you it has a Manuel pump 1972 perkins3cyc. Ed the head
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bob kelley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 475
