跳转到主内容
修复你的物品
维修的权力
商店
The FinePix XP50 is built to deal with the wear and tear of the elements. Repair of this device can be difficult and requires phillips head and hex screwdrivers, as well as prying tools.
6 个问题 查看全部
What should I do if there is water in my camera?
I was taking pictures with my camera underwater and then I noticed that small amounts of water were leaking into my camera. Is my camera ruined or can the water be removed safely?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
Your camera is safe if the water is removed properly. First wait for the exterior to air dry completely or dry the exterior will a soft towel. Then open up the camera and take out the battery. Then either allow the battery to air dry or dry the battery with the lowest hair dryer setting.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matt Wilborn 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 340
