跳转到主内容
The sixth-generation Honda Civic was introduced in 1995. It retained its class-leading handling as it, along with the fourth and fifth generations, had front double wishbone suspension, the advanced independent suspension inspired by Honda's racing research.
52 个问题 查看全部
问题已关闭
speedometer in vehicle only works sometimes
I haven't done a whole lot to get to the bottom of the issue. I did, however, replace the transmission speed sensor, but that wasn't the case. Now I'm going to disassemble the cluster and look for anything out of the ordinary. Any info on this subject would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I had this issue; I ended up buying a second hand speedometer and swapping out the circuit board, that way I kept the original mileage. Has worked great ever since.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 368
