跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1595 个问题 查看全部
Ghost touches - Some Letters Won't Work
Hello great people of iFixit. :)
I received an iPhone 5c on which acetone has been spilled. The plastic on the back made a big bulge, but the battery seems perfectly fine (phewf), I cleaned most of the corrosive and the phone works pretty normal.
Some liquid came into the display, which is visible. The person whose phone it is says that there are often "Ghost touches" - after he locks the device and unlocks it they are gone for a while. Also some of the letters don't work on the keyboard (if the device is in portrait) specifically: 'u' 'j' 'n'. Those parts of the screen also don't react to say swiping the icons. (This happened before I started work and cleaned the corrosive)
Naturally I thought, pfft faulty digitizer, however, when I tested with a new screen, (with no liquid spilled on :P) the same problem persisted, ghost touches and the same parts of the screen consistently not working. I've tried resetting the battery, still to no avail.
Have you got any theories? Things I could try?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个回答
Clean the board again and inspect it!!It's the touchscreen controller Ic either the the connector on the board,if reflow won't help ---replace the touchscreen IC !!!!also Make sure the LCD and digitizer sits well and nothing creates pressure on them!! Peace
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Giovanni Joubert 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 2,799
