Can not get spark
1983 fa50 suzuki bought a new cdi box and coil and stater trying to check everthing but cannot find the problem need help
Suzuki FA50 Moped
jr flick,couple of things that can cause this condition. First off, download the service manual for your moped from here. It will show you how and what to check.Reasons for no spark can be:
"Poor contact between spark plug cap and high tension cord
Broken or improperly connected ground wire
Defective engine kill switch
Poor contact of ignition switch
Broken or short circuited ignition coil
defective wiring among stator, PEI unit and ignition coil
Defective PEI unit"
Hope this helps to get you started. Good luck.
这个答案有帮助吗?
Is there a neutral or clutch safety switch and if there is did you connect it when replacing the coil
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,305
