跳转到主内容
The Kodak Easyshare Z981 features a 3.0 inch bright LCD screen and 26x optical zoom with a 26mm wide-angle lens. The 14 megapixel resolution makes for vivid prints up to 30x40 inches.
14 个问题 查看全部
Why won't my camera take any clear pictures?
Every time I take a picture with my Kodak Easyshare Z981 it comes out blurry and hard to see.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
Common problems that can cause this issue are:
  • If your exposure and focus aren't set properly. In order to set these on the Kodak Easyshare Z981, press the shutter button halfway. When the framing mark turns green, press the shutter button completely down to take the picture.
  • Make sure that your lens is clean and free of dust and fingerprints
  • Check what mode your camera is in - if it is in macro mode, this can be the cause of blurry pictures.
  • When taking photos, make sure your camera is steady. To do this, place it on a flat, unmoving surface or use a tripod.
  • In your camera's settings, set the picture size to be larger.
  • If you are manually setting your ISO speed, a high ISO setting may be the cause of grainy pictures.
I hope that this helps solve the issue you're having!
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Matthew Myers 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 80
总计 5,921
