跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
3021 个问题 查看全部
What happend if I remove wifi ic and turn on phone?
my wifi ic is dead(grayed out) i over heat wifi ic and my phone is not turn on (not get start). when i start my phone wifi ic start heating and when charger is connected then wifi ic start heating. So if i remove wifi ic is my phone get turn on. pls tell me what will happen.... pls help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个回答
If you remove the wifi IC, the phone will not have wifi. So you'd be no better off now than when you started. There is a high possibility to cause further board damage if you are not careful.
这个答案有帮助吗?
得分 0
添加一条评论
When you heat your iPhone it will show that the iPhone is hot so keep it in the freezer for 10 minutes and it will ok
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
onkar 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 263
