跳转到主内容
加入维修社区 - 创建账户
Lenovo IdeaPad Yoga 11S 是一款发布于 2015 年的 2 合 1 可翻转笔记本电脑,配备 11.6 英寸多点触摸显示屏。
Why won't my laptop charge?
My laptop isn't charging even though I have the charger plugged into the wall and the laptop.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Does the device need to be on or off when new battery is installed
由完成的 分享
Hi, The device is going to switch off when you remove the battery anyway but It is better to have the device turned off in a controlled manner by shutting it down first correctly before you work on the battery. You do not want surges caused by disconnecting/connecting the power going through it whilst it is on. You also should not have the charger connected when you do this.
由完成的 分享
添加一条评论
2个答案
If your laptop is no longer holding a charge for long periods of time or always needs to be plugged into a power source to work, use this Lenovo IdeaPad U530 Touch Does Not Hold Charge problem page for possible causes and solutions.
Double-check to make sure that the charger is firmly plugged into the outlet as well as firmly plugged into the laptop. Check the ports to which you are connecting in order to make sure they are not broken. To test this, you can use another laptop, phone, or any device that uses electricity to see if that device will charge. If that device charges, there is nothing wrong with the ports.
If your laptop is still not charging, then there are steps to check what is wrong with the laptop. First, check the battery relation with the laptop. In order to do this, take the battery out and charge the laptop without the battery in it. If the laptop is charging, then your battery has burnt out and the best solution is to purchase a new battery. Next, you can physically feel the cord of the charger. Feel along the wire and see if there are any frayed wires, breaks, or burnouts along the wire. If this is the case, and it smells or feels burnt, then it is best to purchase a new laptop charger. It is suggested to buy a charger with the same voltage as the original charger. This laptop requires a 16-20V charger.
这个答案有帮助吗?
得分 0
1条评论:
Lenovo Edge 2 went completely dead, changed the battery and got new power supply. It charged to 39% and stopped charging. Why?
由完成的 分享
添加一条评论
If your laptop’s battery is unable to charge. it can be due to the several reasons.
  1. charger is dead.
  2. battery is dead.
In such a case, you need to check the charger. now remove the laptop’s battery from your laptop and install it again. now let’s see, if it is charging or not. if not , you may visit: lenovo laptop not charging for more details.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Landon Epps 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 27
总计 11,323
