跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 个问题 查看全部
Fans Noise, Error: 4SNS/1/C0000008:TS0P--124
Hi.
I Add A SSD, Using: "OWC Internal SSD DIY Kit For All Apple 21.5" iMac 2011 Models w/ Tools", Then My iMac is Very Noise.
Apple Hardware Test Said This Error.
TG Pro Said: ODD 4350 RPM, CPU 4000 RPM.
Please Help me.
Update (04/20/2015)
Thanks A Lot.
This is the result on Temperature Gauge Pro.
Update (04/21/2015)
This is My new status:
Update (04/21/2015)
This is my (last) new status. Thank you Mayer! And every one!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
I've had to replace the optical drive fan in several of these. Some of the fans can be fixed by simply pushing on the center of the fan to move it back in place.
这个答案有帮助吗?
得分 5
3条评论:
You said "Hi, i push on the fan and the silence return, thanks, very much. But: On TG Pro: "Fan Diagnostics: These fans appear to be not working properly: Optical Disk Drive (ODD)" What can Do?" First restart the machine and run the diagnostics again. It's Apple part # 922-9120 If you get the same failure use this guide: iMac 21.5"EMC 2428 光碟機風扇更換
完成的
will this also work for the iMac Intel 27"
完成的
Luis, sure it will!
完成的
添加一条评论
JAIME, the problem is most likely related to the sensor of the optical drive fan. Replacing the sensor and/or the fan should resolve this. Try to start under Safe Boot mode. Follow this Apple TN" OS X: What is Safe Boot, Safe Mode?. Download and install this Temperature Gauge Pro. It should help show you what your sensors are telling you.
这个答案有帮助吗?
得分 3
2条评论:
Thanks A Lot. This is the result on Temperature Gauge Pro (below).
完成的
Boot my miMac on Safe mode and still is noisy.
完成的
添加一条评论
Follow what OT has above
Also did you also get this: OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade. You'll need it if you are swapping the old HD for a SSD drive.
这个答案有帮助吗?
得分 3
2条评论:
Thanks Dan, On what disk i need put this sensor?: HDD (Old Original, WD 500 GB) or SSD (New, Recent Adding: Samsung 850 Pro 256GB).
完成的
On the hard drive.
完成的
添加一条评论
Boot my iMac on Safe mode and still is noisy.
Dan, on what disk i need put this sensor: HDD (Old Original, WD 500 GB) or SSD (New, Recent Adding: Samsung 850 Pro 256GB).?
Where can buy this fan or Sensor?
这个答案有帮助吗?
得分 0
8条评论:
It appears you have other issuers here.
完成的
Please tell me.
完成的
Did you open it and find which fan was making noise and push on the center of them to reseat it?
完成的
You only need the sensor I pointed you to if you swap out the HD for the SSD. Its a link so click on the blue to learn more about it.
完成的
Looking at your TG Pro output looks like the HD sensor is working so thats not the issue here. Are you sure you plugged in the sensors back (or correctly) when you disconnected the cables from the logic board to add in the 2nd drive cables?
完成的
显示更多的3条评论
添加一条评论
添加你的答案
JAIME 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 4,153
