跳转到主内容
HTC Desire V smartphone with 4-inch 480x800 display, 5-megapixel rear camera, and Beats Audio.
2 个问题 查看全部
问题已关闭
Why won't my device charge?
When I plug my HTC Desire V in to the charger it will not charge. The battery indicator on the device shows that the batter is not connected (the lightning bolt indicating it should be charging is not present) and my phone doesn't charge no matter how long I leave it connected to the charger.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There may be a couple things causing these issues:
1.Broken Charger:
SOLUTION: The charger itself may be broken or defective; if this is the case you should purchase a new charger.
2. Broken Charging Port:
SOLUTION: The port to connect the charger on the phone itself may be broken and need repair. You should contact the manufacturer if this needs repair.
For more information: HTC Desire V Troubleshooting
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 168
