苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1534 个问题 查看全部
iPhone 5c home button unresponsive
Hi, I've got a 5c with an unresponsive home button, was fine before I changed the screen and dock, since then I've changed the home button flex cable and loudspeaker.
I've stripped it down twice and rebuilt, still to no avail.
I was wondering if there are any further parts that could affect the home button working?
I've ordered a new charging dock part and home button,
but need to know if there is anything else to check or change?
I don't believe I have damaged anything or caused static damage
Many thanks
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
4个回答
已选择的解决方案
The home button works by making contact with 2 pins on the dock connector flex. You can see them around where the home button flex metal pads are suppose to land when the screen is closed. On the dock flex side, they look like 2 metal pins that stick out. If you actually bridge them, the home button activates. With the phone on, try bridging it with a paperclip or knife, it should activate the home button. If it doesn't, it's probably a bad dock flex. If it does work, it just might be that the home button flex is not making contact with the dock side. Could also be that the home button flex was damaged.
这个答案有帮助吗?
按维修分数 1
添加一条评论
Since you ordered a new charging dock, try to overlay it over the exiting one in your iPhone, connect it, and short the 2 golden prongs of the home button like Patrick said (they are at the end of a flat cable, included in your charging dock assembly).
If the home button function works, try again with the old charging dock.
If it works too, the issue is with your home button flex cable not working or not making contact with the prongs.
If neither charging dock work by shorting, your issue is further down the line, on the logic board. At this point, you need to use good magnification (10x is a minimum, 20x is ok) to examine all visible parts of the logic board, especially around the battery and charging dock connectors. If you see anything damaged, part broken off, or missing, try to upload a good quality picture and we'll take it from there.
Good luck.
这个答案有帮助吗?
按维修分数 1
添加一条评论
i changed a screen also and now the home button and speaker are not working.
some videos have said that resistors can be knocked off when taking out the battery carelessly.
i think its the gold pin wires sticking out not contacting the home button but that doesn't explain the speaker. I think its the whole charging dock part that has the ribbon flex included.
这个答案有帮助吗?
按维修分数 0
添加一条评论
thanks guys.
excellent responses and advice.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Andrew Hill 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 302
