跳转到主内容
Clothes dryer repair and support guides.
841 个问题 查看全部
Samsung Dryer Doesn't running in setting and doesn't get hot
The dryer shuts off after a couple of minutes on normal setting but will run on timed dry. It doesn't get hot on timed dry. I have cleand the lint out. I was thinking that it was the heating element but I am not sure if that is the problem with it shutting off.
I don't want to waste money on parts if I don't have too. Any thoughts?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
What model is your dryer?
完成的
添加一条评论
1个答案
已选择的解决方案
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Heating Element
The heating element on an electric dryer can burn out over time. If the dryer doesn't heat, the element should be checked for continuity. The heating element cannot be repaired and must be replaced if defective.
Heating Element Assembly
The heating element assembly on an electric dryer can burn out over time. If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
High Limit Thermostat
Although not common, if the dryer doesn't heat the high limit thermostat can be defective. It can be checked for continuity. If the thermostat is "open" the dryer doesn't heat.
Cycling Thermostat
The cycling thermostat regulates the temperature of the air in the dryer. If the dryer doesn't heat it may be caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at fault when the dryer doesn't heat. Check all of the other components in this troubleshooting guide before replacing the main control board. The main control board cannot be tested easily and must be replaced if it is defective.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
bstecklerx5 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 14
总计 4,335
