跳转到主内容
An optical disc drive released April 2009, identified by model number iHAS324.
1 个问题 查看全部
问题已关闭
My disk tray will not stay open, what can I do?
Whenever I press the eject button, the disk tray opens then immediately closes. I can't get my disk in the tray fast enough, because it will not stay open. I know the disk tray belt and motor are working fine.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
If the disk tray will not open and remain open, you may need to replace the eject button.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
It won't read, won't stay open, and won't eject. It's probably 5 years old. CDW sells it for $19.99. If blowing it out with compressed air doesn't fix it, you have to ask how much your time is worth.
http://www.cdw.com/shop/products/LiteOn-...
这个答案有帮助吗?
得分 1
1条评论:
See if there is a small hole above the eject button. Use a straightened out paper clip inserted into the hole to manually eject the tray. This takes a bit of force sometimes. Sorry, I just realized that this is a school project question.
完成的
添加一条评论
此回答最初是针对另一个问题
There may be a disk jammed in the device. You can try and manually open the drive but be careful as the tray may break. Or you might have to take apart the device and replace the disk tray belt.
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
No No No,
Drive Belt slipping,
I could not find a replacement.
Lite-On is known for this on quite a few of their drives.
Various remedies online are:
1. place belt in boiling water (supposed to shrink belt).
2. use drive belt conditioner.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 278
