What to do if water spilled on it and it got inside
spilled water on it and want to know what is best to do to try to save it?
Been here before. First, shut the machine off and remove it from power immediately. Then you are going to follow this guide here to remove all the major components. Unfortunately, there is no guide for your model as of yet, so the one I linked is the most recent one before that. Once you have removed the logic board, you are going to want to wipe it, as well as the other components, down completely with 70%+ Isopropyl alcohol (rubbing alcohol). Let it dry for 24-48 hours in front of a fan, and then once you are sure it is completely dry, you can begin to reassemble your machine. You can also take this time to clean out your fan if it has dust built up in it. For this task I recommend this toolkit: [关联产品丢失或禁用: IF145-047] , this mat:Magnetic Project Mat , and you will also need this driver: P5 Pentalobe Screwdriver Retina MacBook Pro and Air. The kit will definitely come in handy in the future, but if you want the absolute bare minimum, you will need: this, this, and this. Hope this helps.
产品
$3.99
产品
$7.95
产品
$5.99
产品
$19.95
这个答案有帮助吗?
Unplug battery, remove motherboard, put it into an ultrasonic bath of 1 gallon distilled water, 103 milliliters branson EC. Then take it out of there and put it into a regular baking tray with 99% alcohol. Then let it sit somewhere where it can dry off for a while, maybe by a fan or an air filter or air conditioner. Then put it in an oven at 225f to evaporate any trace of liquid from the cleaning.
Then pray.
Also use a real ultrasonic cleaner, none of that jewelry cleaner junk!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 289
