Knob for settings won't turn off water
This is an older model and when I turned it on for the first time it flooded the utility room. I turned off the water and checked for any leakage but there was none. I reset and ran a full cycle with no problem. However, when I waited about 15 minutes after the cycle completed, the water started to flow into the machine and the knob wouldn't shut it off no matter what setting I had it on. Do I need a new knob for this? Thank you
2条评论
Does it fill with water even when it is turned off?
由 oldturkey03 完成的
Yep, it looks like from what I read in the online manual for this Kenmoore model that I need Kenmoore appliance repairman here, but thanks for the info. I need a new pressure switch.
由 Washwoman 完成的
