2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
524 个问题 查看全部
Slow Start Up after Yosemite Update (not upgrade)
Hi I recently bought a new MacBook Pro 13inch (Early 2015)
I just updated the Yosemite OS X and my Mac has become slow in starting up. Before the update it was like just 2 seconds or so. Now its like half a minute (22 to 30 seconds).
  • How do I fix this?
  • Can I role back the update?
Here are the details of the update:
Remote Desktop Client Update (Version 3.8.2v1.1)
OS X Yosemite Recovery Update (Version 1.0)
OS X Update (Version 10.10.3)
iTunes (Version 12.1.12)
Digital Camera RAW Compatibility Update (Version 6.03)
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
You'll need to boot up on an external bootable drive so you can repair your internal disk. Use Disk Utility from the external drive to run repair permissions and disk.
You should also free up some space on it as well here. Get rid of any old files you don't need or have backups of. There are some deeper cleaning apps you can use to delete log & cache files that could be choking your system up as well.
The very last thing here which we do yearly is defragment the hard drive (not SSD units). Over time your OS files get fragmented as each update extends them to other parts of the disk which then slows the system. But before you defrag the disk make sure to get rid of the junk first!
这个答案有帮助吗?
按维修分数 0
评论:
Actually the problem is fixed. I had to go to Disk Utility, select my default HD & restart, & it was solved.
Happy it all worked out! Please remember to rate (score) and mark it accepted.
添加一条评论
添加你的答案
ahmedalishah 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 2,655
