跳转到主内容
A point-and-shoot digital camera released in 2012 by Samsung.
3 个问题 查看全部
Why won't my camera turn on?
When I press the power button, nothing happens.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
Mine fell down and the lens never eject
完成的
添加一条评论
2个答案
最有帮助的答案
The simplest reason for this problem is an issue with the battery and charging system. Make sure you are using the proper USB charger and cord and they are not malfunctioning or damaged. If everything is working normally there may be an issue with your battery, which you can replace by opening the battery compartment.
这个答案有帮助吗?
得分 1
添加一条评论
the green light just blinks..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Angela Fierst 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 528
