Digitizer doesn't work after replacing
Hi.
Yesterday I replaced digitizer in my Nexus 7 (1st gen) tablet. I separated LCD from the glass, remove the glue from the LCD and after that I glued digitizer to the front frame.
I did not glue the LCD to anything, I only made sure it will be on its place by using a duct tape.
After that, the touch screen doesn't work at all. The LCD is working and I'm able to change volume and everything seems to work correctly except the touch.
Is there anything else I should do to make it work? Or maybe the new digitizer is broken?
Thank you in advance for any help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
