跳转到主内容
Krups single trigger coffee grinder identified as style F203.
11 个问题 查看全部
motor works but blades only spin if grinder is unloaded
The machine seems as if it's working with no load or with very small amount, but as soon as I put in a normal amount of material to be ground then the blades do not turn. It's like whatever connects the blades to the spinning shaft has failed or does not engage properly. Also how do I get the blades off?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
The blade screw is stripped. I have the same problem. I can’t find a replacement blade.
完成的
添加一条评论
1个答案
已选择的解决方案
the blades can be pulled off, pull hard,because the thread inside the plastic blade hub has stripped. Penny pinching on Krups part! you will now have to glue the blade back in place-epoxy resin worked for me.
这个答案有帮助吗?
得分 2
1条评论:
Worked a treat, many thanks.
完成的
添加一条评论
添加你的答案
tanya 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 25
总计 2,390
