跳转到主内容
修复你的物品
维修的权力
配件 & 工具
The second iteration of Samsung Galaxy Tab tablet computers with a 7.0 inch screen.
146 个问题 查看全部
Battery indicator is malfunctioning please help
actually i bought samsung galaxy tab 2 model GT p 3110 about a year ago. Since the last few months it has got some problem . Actually if the tab is not charging, the battery indicator shows tha the tab is charging and makes it upto 100% after that it suddenly comes to 1%. Please give a solution for it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
A quick fix to get back in the game
Shop Switch Kits
任天堂 Switch 套装
Shop Switch Kits
1个回答
How long is it running at 1% & does it automatically shut down at that point ? The lithium batteries have a built in chip that communicates the estimated battery level to the device. Most often devices are charged before the battery is discharged, needing only a top off to 100%. The chip needs to be recalibrated occasionally. Usually letting it run down until the device automatically shuts off & then recharging the battery to 100% is sufficient, but that has to be a single session for the chip to recalibrate. See if that helps
Cheers
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harshit 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 461
