跳转到主内容
Released December 2013. Identified by model number MFC142EN. Repair for this device requires common prying tools and a soldering iron.
4 个问题 查看全部
How do I fix the buttons on my LexiBook Tablet One?
I recently dropped my tablet and not only did the screen crack, but now I am having trouble controlling the volume and turning the device on and off. I believe the buttons might have gotten dislodged.
How would I re-seat these buttons?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
This is a very easy fix.
The first thing you want to do is remove the back plate. This can be done with a prying tool. If you do not have a access to a prying tool you can actually use a credit card or an appropriate equivalent. If you stick the tool/card in between the screen and backing where the two come together you can work your way around the device, undoing the clips that hold it together. Once doing so be careful of not pulling out the speaker. Once you have the device open you can re-seat the buttons and put the backing back on.
For a more detailed description with pictures please refer to the troubleshooting page at LexiBook Tablet One Troubleshooting
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 123
