跳转到主内容
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
125 个问题 查看全部
I can't charge my iPad
When I connect the iPad to the power adapter it appears the green battery with the lightning mark but the i pad won't charge
I tried the restor
I tried another power adapter
I tried another cable
I tried hold the two buttons
But the issue wasn't solved
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
does the cable go in far enough inside the dock?
完成的
添加一条评论
1个答案
最有帮助的答案
Firstly,iPad Air Battery is particularly sensitive to temperature, There are a lot of friends would like to protect it with the Case. But when the weather is hot in the summer, may it will lead to dissipating heat is not good and it failure. So please take it out.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sohaib Khelfi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 1,180
