跳转到主内容
THe HP Pavilion dv6809wm features an AMD Turion 64 X2 processor.
1 个问题 查看全部
Cannot connect to Internet?
Wireless adapter is working; device connects to WLAN, but will not connect to Internet. I have 5 other devices in my shop that connect wirelessly with no problem. What could be the issue. Device connects fine when I plug in the Ethernet cable.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
Hey David,
Try going into device manager and delete the device (not the driver) and reboot. That helps most of the time...if not
Go into device manager again and delete both device and driver. Then reboot while connected to an Ethernet connection....If that still does not work
You may have to go to HP's support site and download the driver there.
Hope this works for you....
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 87
