跳转到主内容
CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
295 个问题 查看全部
Should I purchase a 4 or 4s replacement battery?
I purchased a refurbished iphone 4. The back panel has the model A1387, which is the model# for a 4S. The phone is 4 though, there was no option for Siri when I set it up. So I'm guess they just used the back of 4S replace a broken one.
I need to replace the battery. Should I order the 4 battery or the 4S? Or is there another way to tell what's on the inside without opening it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I would recommend purchasing the iPhone 4 battery because that is supposedly the model of the unit. The difference between the iPhone 4 and the iPhone 4S is that the battery connector to the logic board was changed from the right side of the battery to the left side of the battery, respectively so you will notice rather quickly whether or not you have the right battery.
If the unit itself is an iPhone 4, then buy an iPhone 4 battery. It can be purchased here: iPhone 4 Battery.
Also, here is the link to the repair guide to help you along: iPhone4 电池更换.
Hope this helps and please keep us updated on your progress.
iPhone 4 Battery图片
产品
iPhone 4 Battery
$11.99
这个答案有帮助吗?
得分 0
1条评论:
Got the 4 replacement and hubby installed it last night. I got off work 2 hours ago and my phone isn't only still alive, but the battery level is way more than half still. So far, so good. Thank you!
完成的
添加一条评论
Go to settings then about and go to serial number now hold finger on it then copy it
And paste it in to the link I gave you it's a warranty checker but it will tell you the model iPhone you have
https://selfsolve.apple.com/agreementWar...
这个答案有帮助吗?
得分 0
1条评论:
Thank you, that was helpful.
完成的
添加一条评论
添加你的答案
CarlaGMrs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 203
