跳转到主内容
任天堂3DS XL 2015在市场上被称为新任天堂3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
369 个问题 查看全部
New black ZIF Connectors on motherboard
What are those new ZIF connectors called? Old ZIF had a white tab and locked into place. these new ones are black and doesnt go all the way up or lock back down. What am I doing wrong? This *New* 3DS motherboard appears to be a mix of old ZIF and new ZIF connectors. the black ZIF connectors are for the Homebutton and LCD brightness and others.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Circle in Red to see what I'm talking about.
http://imgur.com/N9x3kRk
完成的
添加一条评论
3个答案
最有帮助的答案
For those in the future it is the JAE FA1004SA1-R8000:
https://www.digikey.com/products/en?keyw...
这个答案有帮助吗?
得分 4
3条评论:
How hard it is to weld it into the motherboard ?
完成的
There are 8 pins to connect per connector. I heat shielded the board and heated the board on the underside with a hot air gun to remove the old connectors. Then tinned the contacts, put the new piece down and heated from the underside again. After the new piece had been soldered to the board I took the soldering iron to the pins on the top side using 0.03" dia solder. I also heated the top contacts by holding the soldering iron to those pins, perhaps a bit overkill but they are soldered on there well now. Be sure to clean any flux residue with a soft brush and rubbing alcohol being careful not to lift the connectors. Solder paste would have made the job much easier. This took me about 2 hours to do 3.
完成的
i am working on one now and the link you gave has an option for 3 different part numbers. how would i know im gettnig the right one
完成的
添加一条评论
They're still flat cable ZIF connectors, they just don't have locks. You shouldn't need to pry them up to remove the cable -- at least I didn't.
这个答案有帮助吗?
得分 0
添加一条评论
What I did was take the cable out of the connector, place it back roughly where it's supposed to go, then apply a small amount of pressure to the BACK of the connector, opposite of where the cable goes in, where the 4 connects look like a hinge of sorts. Apply just enough pressure to see the connector bend down to where it's supposed to go. Pressing on the front of the connector, where the cable goes in, didn't do much for me. Still can't get my MIC to work... Still, light sensor and home button work excellently.
这个答案有帮助吗?
得分 0
1条评论:
Yeah I tried that, the only way for me to get it working was for me to send the device to Nintendo to replace the systemboard. It will work if I use my thumb to apply pressure on the ZIP connector while the device is on which is how I figure its wasn't "locked" all the way down but it was probably just a faulty ZIP connectors.
完成的
添加一条评论
添加你的答案
Simon Poon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 30
总计 3,250
