跳转到主内容
A 10-megapixel, point-and-shoot camera developed by Canon in 2010.
21 个问题 查看全部
Why isn't my camera's screen showing pictures/images?
When I turn on my camera and the light is on which shows it is powered on, nothing appears on my screen when I aim to shoot. I am not in a dark environment, there is nothing on the outside lens, and I have never had this problem before. What can I do to fix this and what could be wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
  • The screen is cracked or water damaged. The screen may need to be replaced.
  • The wires that connect to the screen are faulty or disconnected. Disassemble the camera to reconnect the wires or determine other types of internal issues.
这个答案有帮助吗?
得分 1
添加一条评论
Hi, it's possible that your screen may be damaged or there's an internal issue. There's a replacement guide for this if you're interested: Canon PowerShot G12 LCD Screen Replacement
这个答案有帮助吗?
得分 0
添加一条评论
It's a common failure, a mechanical problem on the lens shutter :-(
这个答案有帮助吗?
得分 0
1条评论:
How do I fix it
完成的
添加一条评论
添加你的答案
Nathan Meuwissen 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 32
总计 2,359
