SSD boots over USB, doesn't boot connected internally.
Hi,
I tried replacing my internal HDD by an SSD (crucial m550 - 256Gb) on my Mac with the latest OS running.
I made a clone with carbon copy cloner from the original HDD to the new SSD (ca. 130Gb).
The SSD boots perfectly when connected over USB, but is not found when connected internally.
However, when I updated de SSD's firmware, I booted from a CD with the SSD connected internally and it was found without a problem.
When I boot with the SSD internally connected I just end up with a grey screen and a fold+questionmark icon.
- i updated firmware on ssd
- i checked if firmware on mac was latest version
- I cloned the disk again and checked there was a safety partition created
- a clean install from scratch is not an option: i've got software from my work that I can't get a new regkey for.
…I really have no clue what to do, but I can't get my SSD working. Any ideas? Thank in advance!
2条评论
The support of Crucial mailed me I should partition the SSD correctly to install OSX. Of course that's not helpful, since I can boot OSX through USB already.
(Correct partitionings is the GUID partition table --> That seems to be taken care of by carbon copy cloner.. You can check it in the Disk Utility)
由 Saber 完成的
No one here replied, but luckily the support of Bombich software (makers of Carbon Copy Cloner) provided me with this solution:
We have received numerous reports of hardware compatibility issues when installing a cloned hard drive from an external enclosure into various Macs.
1. Shut down your Mac
2. Install the new disk inside your Mac and put the original disk in your external enclosure
3. Boot your Mac from the original startup disk in the external enclosure -- hold down the Option key while booting your Mac to get to the startup disk selector screen
4. Re-initialize the new disk (in the partition tab -- reapply the "1 partition" scheme to the disk)
5. Clone your original source volume to the new disk
6. Set the startup disk to the new disk in the Startup Disk preference pane and restart your Mac
Note: Step 4 is very important -- be sure to apply a new partition scheme to the disk, don't just erase the volume. This video indicates how to repartition the disk: http://www.screenr.com/SQM
由 Saber 完成的
