跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3499 个问题 查看全部
phone is not charging
I tried a known good cable and it still didn't charge so I replaced the charging dock with a known good one and it still didn't charge, replaced with known good battery still didn't charge.. waited a little and tried it again and it started working! Any idea what happened? Maybe reseating the cables helped but I doubt it as they would have not shifted inside the phone?
Also, the "bad" dock and battery that I placed in the other phone also started charging.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Sounds like the charging port is the cause. Try a known good one. Good luck.
这个答案有帮助吗?
得分 0
评论:
No I tried a known good one already as I stated and it still wasn't working,then I unplugged everything back in and it started working, also tried the "bad" charging port on the known good phone and that one started charging too.
完成的
Did you try a charging port only, or charging port with flex ribbon unit?
完成的
I swapped the ribbon,now its not charging again.
完成的
添加一条评论
添加你的答案
Sam 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 210
