跳转到主内容
The Asus MeMO Pad 10 features a vibrant IPS display with a 1280 x 800 resolution.
19 个问题 查看全部
Asus MeMO Pad 10 won't power on?
I have a MeMo tablet that won't turn on. It does charge (the LED will turn green after awhile). I've tried all the various button-holding suggestions, poking the reset button, opening it up and leaving the battery unplugged for a time, and even swapping the battery with a known good one (I have two of these), but nothing has made any difference. The device was working fine, and then suddenly just stopped. It was not dropped or bumped recently. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
添加一条评论
3个答案
最有帮助的答案
How do you open the tablet up to replace the battery?
这个答案有帮助吗?
得分 1
添加一条评论
If you search around there's a youtube video that will show you how to do it. The main shell comes apart by prying the back off with a thin blade. Then you have to disconnect one multi-pin cable, and take out a few screws to free the battery, but it's not too bad. No glue!
这个答案有帮助吗?
得分 0
添加一条评论
i get no charge even
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ifixgrax 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 3,117
