跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
问题已关闭
GPS OK disassembled. GPS fail assembled.
Hi.
I have a iPhone 5 where the GPS almost disappear when I re-assemble the device. The GPS time is updated only approx. every 12 seconds.
If i lift the screen just a bit, the GPS signal is OK again. Then the time update every second like i should.
What am i missing here? Some ground touching where i shouldt? I checked the interconnect cables, and they are both connected as they should.
It is a 3rd party screen.
Hope someone here can help me find a solution :)
Thank you.
Updated pictures
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
OK. Found a solution. I put some kapton tape over the GPS connectors in the top of the phone. Now it is running perfectly. See attached photo.
这个答案有帮助吗?
得分 1
添加一条评论
Can you remove the display and take hi def pictures around the top area, both the display and the phone internals?
The case or MLB is definitely replaced, so the GPS antenna area is not properly installed.
这个答案有帮助吗?
得分 0
2条评论:
Sure. no problem. Give me 5 minutes. MLB? :)
完成的
Pictures added.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 91
