跳转到主内容
Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
76 个问题 查看全部
What is this loose part which was rattling in my Mac mini?
My Mac mini was rattling with a loose part. I used the guide to open it up and found the culprit. I don't know where it goes. It is small like the size of a safety pin and 28mm in length and 5mm width and is metallic with two legs widening out and a flat headed top bending up like a contact. Please help.
It looks a bit like an led component without the LED.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
I've uploaded a photo on my Facebook page
It's also my avatar picture. Please help.
添加一条评论
2个回答
已选择的解决方案
While hard to see I think you found the power supply clip. Here's a better image of it and where it's located: Power Supply clip.
Follow this IFIXIT guide to get to it: Mac Mini Mid 2010 Power Supply Replacement. You'll need to get to Step 22 in taking the mini apart, then reverse from there.
这个答案有帮助吗?
按维修分数 3
评论:
Brilliant thank you
添加一条评论
That part holds the female Power Adapter in place inside of the Mac Mini. Technically it just locks it in place as the adapter is held in place by tension.
It's really a not needed part.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
shamim1980 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 252
