跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
How can I put my Nintendo DS to its original colors?
My Nintendo Ds top screen its colors are almost in white when I turn on. What can I do too put it back to his original colors.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
If you can still make out the image, and it's not completely white, then it's likely not the screen or cable that is the problem. If you unscrew the battery cover you will see two small holes with what looks like Phillips screw heads. Turning these adjusts power to the screens, and improper power settings can make the screen appear too light or two dark. Adjust the screw (slowly!) until it displays properly.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Kevin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,621
