跳转到主内容
Having trouble with your Kodak EasyShare? Check out our repair guides to help get you back to taking beautiful pictures.
4 个问题 查看全部
Why won't the camera turn on?
The camera will not turn on no matter what I do.
I press the power button and the start up noise and start up display screen do not appear.
What can I do to make it turn on?
Please help me out,
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hello there!
If the camera doesn't seem to be turning on, it may be possible that the battery has lost its' charge. If you can locate the charging device that came with the camera, you can place the battery inside of it and allow it to recharge for a few hours. Hopefully this does the trick! Comment on how it went!
Good luck!
Caitlin
这个答案有帮助吗?
得分 0
添加一条评论
try blowing compressed air into the optical lens i had this issue were the lens gets jammed and it prevents from fully opening my would shut off put some air through that area and presto. eventually had to tear down the camera to completely clean it but hopefully that is the issue with yours. Good Luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Elizabeth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 33
总计 1,693
