跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 个问题 查看全部
Why can't I delete my photo's?
I'm trying to delete photo's that I accidentally uploaded but now my phone is saying "unable to delete." How can I delete these photo's since I don't want them on my phone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 12
14条评论
Why can I delete my shopping cart so I can start new I've been asking for this for quite a while if you can't help me I'm going to erase the app cuz I don't want to order something and then they're going to charge me for everything that's on the shopping cart thank you
完成的
Having problems deleting pitches on my Galaxy 8 plus I hit the delete but they're still there and they won't delete how do I solve that problem and delete them
完成的
I have the same question
完成的
The same thing is happening to me with my Galaxy 9
完成的
Ok turns out you have to go to your Google Photos and delete it there first so then it'll automatically delete from your gallery.
完成的
显示更多的9条评论
添加一条评论
5个答案
最有帮助的答案
Recommended from online:
Go into Settings----->Accounts and Sync---->Tap Google----->Uncheck "Sync Picasa Web Albums".
Go into Settings----->Application Manager---->"All" tab----->Find Gallery and tap "Clear Data"
I think your next step is going into the gallery app and tapping clear data. I believe it will only delete the cache and not your pictures.
这个答案有帮助吗?
得分 4
2条评论:
I tried it all I could find and never done anything to me until I found this, specially the second line made it finally possible to delete and on two different places. Deleted it all and completely to make sure Data and Cache as well, now it can start normal again and room is more now too for new stuff.Anything else is on my PC anyway so nothing really got lost at all but gained it all
by the way, I did it on Samsung galaxy II plus
完成的
It's been a few days now and I still can't delete my photos. Please help.
完成的
添加一条评论
I has same problem and pulled me and then realised if you go into tools click on my files and then images and if you delete them from there they won't show up on youre gallery x
这个答案有帮助吗?
得分 1
添加一条评论
I figured out how to fix it. Samsung has this thing where they sync images back to your phone so when you delete it, it automatically goes back into your phone or tablet however there is a simple way to fix this. How I fixed this problem for me, I went to the gallery app,under settings I turned off samsung sync and it automatically fixed my problem. I hope it works out for you guys
这个答案有帮助吗?
得分 1
添加一条评论
I did what Tonie suggested and it worked for me.
Thanks Tonie Chan
这个答案有帮助吗?
得分 1
添加一条评论
You can easily delete pictures from file manager instead of photo related apps.
Its work for me ;)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Julie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 13
总计 104,040
