The LG Thrill is a 3d enabled Android smartphone. The thrill has 8 gigs of internal memory with dual core processors, a camera with LED flash and wifi connectivity...
4 个问题 查看全部
My phone won't charge.
I forgot to charge my phone last night so it was almost dead when I woke up I decided to charge it and when I plugged in the charger, nothing happened. I left it there for an hour and still barely charged at all. I wanted to know if there were any solutions to this problem?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
One of the most common problems is metallic surfaces inside the USB port and the USB charger aren't making clear contact. The reasons could be from manufacturing defects or continuously plugging and unplugging the charging cable.
All you need is to shut down your phone take out the battery, use something small (ex: toothpick) to lever up the tab inside the USB port of your smartphone. do these steps very carefully and slowly then reinsert your battery and plug it in again. Most likely this was the cause.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Khbero Baker 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 4
过去的30天: 19
总计 800
