跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
797 个问题 查看全部
What part should I replace if iPod won't turn on at all?
My iPod won't turn on at all. It was working perfectly a few hours ago, turned it off, wouldn't turn on again after a few hours. When I try to, I just get a blank screen. I don't hear anything, so I don't think the hard drive is spinning. Nothing shows up when I plug it into the computer. I've already tried resetting it, many times - like 10+.
I'm thinking I need to replace the battery, but it seems like people usually get a low battery message in that situation. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
First of all, I'm not experienced with iPod repairs. But from general knowledge I would say that if it was the battery, it should still show up in iTunes or power up when you connect it to external power.
完成的
添加一条评论
3个答案
已选择的解决方案
Rousp is correct in his assumption, I would say its more of a HDD or logic board problem.
这个答案有帮助吗?
得分 2
添加一条评论
I would replace the battery, worked for me.
这个答案有帮助吗?
得分 1
添加一条评论
I have the same problem with my Ipod classic G6. But I take off the battery and checked it with a multimeter. The Battery gives 4,2 V. Is this correct? It should only give 3,7 V.
When I try to connect it to the computer (with the disconnected battery) nothing happens. No drive spin up, no recognition of the device, no screen, nothing. :-(
So I think it's the logic board. Or what do you think?
Is there any repair tutorial out there for the logic board? Perhaps it's only a smd fuse or something like that.. :-)
Oh... I'm sorry for my bad english, but I can't find a german site with this quality. I like your site!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
notquitealibrarian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,178
