跳转到主内容
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
133 个问题 查看全部
Motherboard repair U701 voltage
My TAB2 doesent show eny lifesign at al.
I meschure voltage on U701 WICH SHOULD BE 1,2V
it is 0,9v not shure if that is the problem?
How to test the ON OFF switch?
Cant find this in the repair manual.
Charging seems to work, batterypower is 4.0v.
regards, patrik
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
patrik, check the voltages on the other components as well. Check the U701 output voltage on C732 > 1.3V, C733 > 1.8V, C734 > 1.2V, C735 > 1.2V C736 > 1.2V. If you do not get that voltage you should replace it. I'd consider a new power flex first. As for the switch, it appears to connect at pin 1 and 2 on HDC500.
这个答案有帮助吗?
得分 2
1条评论:
Thank you for fast answer, i have al the voltage you sugest exept for 1.2v at C734 and C736 that is only 0.9v
Also i mesure charge 5.0v at C508
Do you Think the ribbon Cable could still be faulty when i have 5.0 v at C508 and it sems that battery is charged at 4.0v ?
Is ribbon Cable at al used exept for charging?
Best regards from Sweden!
完成的
添加一条评论
Patrik. I happen to have exactly same problem with a P5110 I have for repair: all voltages except for 2 are ok. The 2 off are exactly the same wrong voltage of 0,9V.
I have done, according to samsungs service manual, a replacement of U701. Unfortunately the problem is exactly the same with the new chip in place.
Next thing I will try is to swap out the oscillator OSC700. I will keep you posted with the results in the coming days.
这个答案有帮助吗?
得分 2
5条评论:
Great Gido! My tablet died in my hands when i put the charger in. At first i thought it was a bad battery so i bought a new Samsung original battery. Unfortunally no luck with that.
Whould be nice if somone could sugest comon problem with this tablet.
完成的
Just received the new OSC700. Replaced the OSC700 and now there is a clock signal again on the oscillator. Unfortunately the 2 voltages are still too low (0,9V) and tablet does not power on.
I will dig deeper to see if I can find the problem. To be continued...
完成的
Gido, I have the same problem 0.9v. You repaired?
完成的
@Gido Nijenhuis - Did you get to the bottom of this? Where did you get the chips/components from? Thanks.
完成的
i had same problem, but still looking how to access U701 ic, my battery is 4 volts, I already charge it separately, still dead tablet, I wish to hear from you, thanks for sharing
完成的
添加一条评论
添加你的答案
patrik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 1,321
