跳转到主内容
The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
56 个问题 查看全部
will power steering pressure switch cause hard steering at low rpm's
just replaced lower steering shaft & still hard to turn at low rpm's. steer's fine & easy after 10 mph.,so pump is working,could pressure switch failed or could resivoir filter be clogged?? how can i check these problems?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
How many miles on the truck and have you tried a flush of the pump and steering fluid
完成的
添加一条评论
1个答案
yes , it will . look for a collapsed hose or dirt in reservoir... if you can hear it whi ning when you turn the wheel its your power steering pump
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
john 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 1,627
