跳转到主内容
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
Won't boot from OS10.4 from hard drive
I upgraded the OS on this computer and now it won't boot--just grey screen with spinning gear--no question mark. Will boot from external drive. I have wiped the drive and done a clean install. Runs fine when I have the original OS10.3 installed, but won't upgrade even to later 10.3 updates,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
What OS did you install? Tell me about the upgrade disk, please.
完成的
添加一条评论
2个答案
已选择的解决方案
If it boots from 10.3 but not 10.4 my best guess is, not enough RAM. 10.4 needs at least 256 MB. If one of your sticks or slots is bad or you just don't have 256, 10.4 will not work. From your 10.3 start up go under the Apple to "about this Mac" more info, memory and see what your book is reading. Let us know. Thanks
这个答案有帮助吗?
得分 3
1条评论:
Good answer + Ralph
完成的
添加一条评论
Thanks for the replies.
I ran the Apple hardware diagnostic disc, everything came out OK. The OS disc is a retail Tiger one. I also took the PowerBook to the Genius Bar at the Apple Store, they did exactly the same thing I did, told me to do a clean install--but to no avail. Machine won't boot from Tiger, but boots fine from 10.3.
I was hoping there might be a simpler solution--I don't feel confident after looking at the procedure to replace the hard drive and I'd rather not sink any more money into an outdated machine.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Pieter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,044
