跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Repair and disassembly guides for padlocks.
1 个问题 查看全部
jammed the padlock on my security gate. How do I fix it?
Some foreign things were put in my padlock. We remove most, the key goes in, but can't open it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
2个回答
最有帮助的答案
Try spraying WD40 into the lock and/or try can'ed air. Either one should flush out any small pieces still inside the key slot.
Did someone put something into the hasp part of the lock?
Are you sure you have the correct key?
If either of these are true you may end up needing a locksmith or a bolt cutter.
这个答案有帮助吗?
得分 2
添加一条评论
Go onto eBay, Amazon, or just search Google to get a set of broken key removers. They are relatively cheap. (Under 5$) they come with a lot of different jigs and sawtooth picks. Good for getting almost anything out.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
daddy16cool 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 2
过去的30天: 18
总计 1,838
