跳转到主内容
Samsung's fitness-oriented smartwatch, featuring a curved super AMOLED touchscreen display. First released in April 2014.
35 个问题 查看全部
gear fit won't turn on,
ive held down the button, ive charged it, i disconnected bluetooth,i did not drop it, and still nothing but a black screen. ive had this for 3mos so i know the battery should be fine and all the connections are clean.
any other suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
it does vibrate when i hold the button down, but thats it.
完成的
添加一条评论
1个答案
I've had something like this happen in the past. It should just need a reset, if you haven't tried that already. Plug it into the charging cradle and hold the home button for 7-10 seconds to reset it. Turn the bluetooth connection off from your phone while the Fit is off. When the Fit restarts, you should be able to turn bluetooth back on and reconnect it.
If you have tried a full reset, then I'm sorry.. no other ideas. I wish you luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
karen 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 14
总计 1,293
