跳转到主内容
The Asus Q501LA features an Intel Core i5 4200U (1.60GHz) processor.
27 个问题 查看全部
Why isn't my battery charging?
I am having problem with my asus laptop.
The battery suddenly stopped charging. when i connect the charger the battery icon gives message
(0%,connected,charging) but the battery won't charge and the laptop shuts down when i remove the charger. My laptop is ASUS Q501LA and its 13 months old. Please suggest me how to troubleshoot this issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
You most likely have a bad battery. From what you describe the OS detects the charger properly and that the charger has enough amperage to charge the battery.
这个答案有帮助吗?
得分 0
添加一条评论
Sometimes the adapter connecting the battery to the motherboard gets loose from unsafe carrying. I've opened this laptop a few times, changing the hdd, ram, and this has happened to me a few times. To illustrate this better I attached a link to the part I am referring to. (my laptop disassembled ) Once you disassemble the laptop, it should be a quick fix.
https://www.dropbox.com/s/yg6uaj78tsrn5h...
这个答案有帮助吗?
得分 0
1条评论:
Hi, can you please repost on how to do this or send to epvbcoach@yahoo.com Thank you.
完成的
添加一条评论
You may need to replace your ASUS Q501LA battery. I met the same problem as you, and I bought a new ASUS Q501LA battery at this site: http://www.laptop-batteries.com.au/compu.... It makes my laptop come to life. satisfied with the battery.
这个答案有帮助吗?
得分 0
1条评论:
I have this Q501LA after vacation it would not start even plugged in. Read several posts suggesting a new battery so got one installed it and it worked for one charge almost dead now. Charger cord does appear to be good but plugging in doesn't charge or run the laptop.
完成的
添加一条评论
添加你的答案
swapnil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 2,399
