跳转到主内容
The Keurig B77 Coffee Maker is a single-cup coffee maker made by the Keurig company.
12 个问题 查看全部
Unit will not turn on
Unit suddenly will not function after working fine 1 hour ago. The touch button to turn the unit on will not light up and their is no display on the screen
回答此问题 我也有这个问题
这是一个好问题吗?
得分 17
1条评论:
We have a problem about the same. Our power company installed a new transformer on our line and the unit worked prior to that then nothing we've tested the outlet and it's fine. Can we re-boot the unit?
完成的
添加一条评论
4个答案
no power to unit whats up ? is there i fuse somewhere
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem, just got this coffee maker. Worked fine for a day, then it started acting weird. It wouldn't brew every time I pressed the button. Then all the sudden it stopped working and the screen wouldn't come on. Ridiculous!
这个答案有帮助吗?
得分 0
1条评论:
I'm having the same issue. My unit is a couple years old. Where can I take it to be repaired? Is it completely kaput or repairable?
完成的
添加一条评论
Defective on-off switch
这个答案有帮助吗?
得分 0
1条评论:
how do I fix that ?
完成的
添加一条评论
My keurig coffee maker will not turn on anymore . I had just used it to make a cup of coffee ,for the next one it would not start.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Neil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 3,181
