跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
571 个问题 查看全部
Suddenly unresponsive, small visible dent on back
This iPad Air is almost 2 years old. I put in in a drawer for a few days. Took it out and it is compeletely unresponsive to touch. I have
- Reinstalled iOS8.3 from scratch
- Reset with power+home button
Even after a clean reinstall with no restore of backup it just is completely unresponsive to touch.
- I have not dropped it
- No liquid damage
Has anyone experienced this? Is there any fix other than go to Apple (who will charge me I think since it is out of warranty)
  1. UPDATE ##
I was wrong about the "no damage". Seems there is a small dent on the back. See enclosed picture where I have outlined the dent. Somebody has used it and put it back obviously. I don't care who did it though. I just wonder if anyone has an idea if this dent is in a critical place that could affect the touch scree. The home button seems to work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
If it is under warranty then i would suggest bringing it to apple. If not then a local repair tech with a good reputation im sure they can sort this issue out for you as more than likely it is not a software issue as you have done a full factory restore which leaves only hardware.
Here are some trouble shooting steps.
- When the iPad Air is off, use a damp microfiber cloth to clean the screen gently.
- If there’s a screen protector on your iPad Air it could be the culprit.
- Try pressing the Home button three times or check in Settings > General > Accessibility and make sure that VoiceOver isn’t turned on.
这个答案有帮助吗?
得分 0
2条评论:
I have done all the things you mention. The Home button is unresponsive so there is no response to any click or touch. It is definitely a hardware issue. The iPad is out of warranty (2 years) but I will check with an Apple store. If I knew for sure it was the digitizer I could replace it. But since it also is the home button I suspect it is a logic board issue.
完成的
I took this to an Apple store and they said there was a small dent in it so that was the reason and they would not replace it for free. The dent is just to the right of the Apple logo on the back. Everything is working fine except that it is totally unresponsive to touch.
完成的
添加一条评论
I have to say, I have the same exact problem. Tiniest dent, the stupid thing can't turn on.
这个答案有帮助吗?
得分 0
1条评论:
I had to pay apple for a replacement unit. Too bad I was not able to fix it.
完成的
添加一条评论
添加你的答案
asle 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 11
总计 1,546
