跳转到主内容
Repair and service information regarding the Lenovo S920, an Android smartphone that was announced in March 2013.
5 个问题 查看全部
Why won't my phone power on?
hai..i have lenovo s920..but the problem is cannot turn on but red light lighting when i connect to pc.is there have solution that can guide me.or my phone cannot been repair anymore?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 39
3条评论
My lenovo s90 is not working and it is not working and it is not oning.
完成的
i acquired a new lenovo k5ic78, i have tried to charge but it cant get switched on. what could the problem be?
完成的
need help please
完成的
添加一条评论
8个答案
最有帮助的答案
My lenovo mobile not able to on
这个答案有帮助吗?
得分 2
添加一条评论
I dropped my lenovo S920 hard in the floor. When I turn it on it won't open. When I try to charge it, it's charging. Do you know how to fix it?
Update (08/29/2015)
I dropped my lenovo S920 hard in the floor. When I turn it on it won't open. When I try to charge it, it's charging. If you're gonna ask if it's low bat, it's not. Do you know how to fix it? Please help me with this problem.
这个答案有帮助吗?
得分 1
5条评论:
First you have to check whether any short circuit on PCB, No shorting then you check the ON?OFF switch. any damage resolder or replace the ON/OFF button.
完成的
If there is no damage in ON/OFF button flash the device . again it won't power ON then reheat the cpu and check, reball the cpuand check, Replace the cpu and check. no solution now change the PBA.
完成的
U do all these things after check the battery output. and have to check oscillator outputs..
完成的
I have the same problem .. but I did not drop my phone ... I just woke up in the morning trying to open my phone and the same problem happened ....
完成的
i have a problem of s90 lenovo, it wont power on, but it vibrates and there's a red light besides the camera hole(front).will you help me how to fix?
完成的
添加一条评论
i had the same problems .. but i manage to solved it.
download the stock rom and try flash it using SP Flash Tools .
your device will surely revive from dead ..
:D
这个答案有帮助吗?
得分 1
添加一条评论
so many answer, number 1 is , no battery
这个答案有帮助吗?
得分 0
添加一条评论
What do I do ? I bought a phone from Lenovo then when it came I charged it for about 15 h then when i went to turn it on it didn't do anything so I charged it for 6 h and it still didn't do anything . It's been almost 2 days and it still doesn't turn on . I tried pressing volume + and power still didn't work I tried volume- and power still didn't do anything, I tried +and - and volume doesn't work . PLS HELP ME!!!!!
这个答案有帮助吗?
得分 0
添加一条评论
have same problem. need help
这个答案有帮助吗?
得分 0
添加一条评论
step 1 gather some strength
step 2 hold your phone really tight
step 3 smash it to the ground and say &&^& this.
这个答案有帮助吗?
得分 0
添加一条评论
what you need is you want to kill kids ( In Game ) until you’ve gathered sum POWER and then what you need is Flash your phone with stock ROM.
ENJOY :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ejam219018 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 12,985
