跳转到主内容
大量索尼数码和胶片相机的维修指南。
799 个问题 查看全部
Sony Alpha A300 tells me 'Unable to use card'?
Camera tells me 'Unable to use card'. Its not been dropped or got wet, in fact, I was taking shots on it in the morning, got home and got this error. If you take the card out, the camera works fine. Any suggestions? I've checked that none of the pins are bent in the card slot, formatted the card, cleaned inside with a small brush, blown air into the slot and switched the camera on/off countless times.
Any suggestions would be extremely helpful, thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
hello there after few years :)
I had got same problem. Change card was needed and problem gone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
adamterrey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 154
