跳转到主内容
加入维修社区 - 创建账户
型号 A1369,1.6、1.7 或 1.8 GHz 处理器,64、128 或 256GB 闪存存储
How long is a new battery's shelf life?
The battery in my 2011 Macbook Air began raising a "replace immediately" alert after 2.5 years of age. I ordered a new one, and waited for the old battery's charge to degrade, but it never did. That was over a year ago. It can still last for about two hours on a full charge. In the meantime, the ifixit battery I bought is still sitting on the shelf in its shipping box. While I continue to wait, is there any danger of the new battery getting "stale" and not working well when I finally do swap it in?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Hello,
from my experience the degradation of a battery life depends on the discharge/charging cycles. So if you leave the battery in its package on the shelf for a long time the chemical reactivity of the single battery cells should remain at a very high level. Although the battery could loose some voltage after some time.
这个答案有帮助吗?
得分 1
添加一条评论
I've exactly the same question, but my MBP 2009 Model still holds a charge of 2-3 hours. I've got a new battery sitting in my shelf since OS X keeps telling me to replace it, but I don't want to replace it until the old one inside the MBP has been completely used out.
Did you find any answer to your question?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
johnsgchurchill 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 25
总计 1,352
