跳转到主内容
The 2008-2014 (fifth generation) Honda City was unveiled in Bangkok, Thailand in September 2008. In South Africa, the Honda City is called the Honda Ballade.
19 个问题 查看全部
How to update 2014 Honda City's Infotainment system for CarPlay?
I have a 2014 HONDA City. One of the I/O interfaces is an HDMI port. This allows some apps to run on the screen (E.g. Waze, AppRadio etc).
How can I update the Infotainment System for compatibility with CarPlay?
Is there a way to get the full CarPlay functionality?
How can I update my infotainment system to a newer version?
The issue is that I am currently living in UAE, and the dealerships/service providers do not know anything about CarPlay, let alone help me with this question.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
This question was migrated from http://meta.ifixit.com/Answers.
完成的
need solfware update
完成的
添加一条评论
3个答案
已选择的解决方案
After a long search, it turns out that this system can’t simply be updated via software to include CarPlay or Android Auto.
However I found an alternative which is decent, but not perfect.
https://www.navtool.com/carplay.aspx
I’m not sure if there are other systems like this out there, and I have also yet to try this personally. But it’s a good workaround if you want to try it yourself.
(got this solution thanks to Reddit)
这个答案有帮助吗?
得分 0
添加一条评论
Honda says its a new system and you can not update. Is that true.
这个答案有帮助吗?
得分 0
1条评论:
Yes, unfortunately, I believe this is the case.
完成的
添加一条评论
There's also https://www.mergescreens.com/collections... ++++
as another possible solution, though I don't have much information about it.
Remember to research and check reviews before making a decision.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tanuj 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 67
总计 7,607
