Idle high, Overheating occurs quickly
1994 honda accord coupe had water pump replaced. Idling is high. Overheating occurs quickly. Cant figure out where the water is coming out of. Should radiator be replaced?
Tina, check your radiator hoses to make sure they are properly clamped and that the hoses are okay. If so, it is possible that your radiator is leaking. Any shop should be able to do a pressure test to see exactly where it leaks. Yes, there is a distinct possibility that you may have to replace the radiator.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,165
2条评论
Is the water leaking? Checked the thermostat? what else did you check? do your fans come on?
由 oldturkey03 完成的
Water is leaking. Fans come on. Thermostat was replaced. But there is water leaking from a area underneath the radiator.
由 Tina 完成的
