跳转到主内容
修复你的物品
维修的权力
商店
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
4050 个问题 查看全部
How to sort screws without reference
Hey everyone! After being helped so well on my first question here by @Rany, i felt confident this was worth a try. As i said in my first question i am building a Iphone 5S starting with only the motherboard and the home button flex. I have every part, except the earthing clip but i have ordered that, and had a pre-installed 5S back housing with small parts, a original 5S back housing with all parts,a new lcd with all parts, 2 screw sets and a set of all small parts in a 5S. The parts, and mainly the screws, i need guidance on. How do i distinguish screws from each other? Also in my test run with everything installed, except the earthing clip ;), the phone does heat up quite a lot and the screen is a bit jittery but that i think is because the connector shield isn't on properly because i cant find the screw that's supposed to go in top right. I know that its supposed to be de-magnetized but i cant find one that is :( Sorry bout the long post Thanks in advance for any insight.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
1个回答
已选择的解决方案
The repair guides here will give you the screw size. A digital / electronic caliper will allow you to measure the screws and match them to their appropriate place.
这个答案有帮助吗?
得分 1
评论:
Nice!Thank you for the solution! Any ideas on the over-heating? Also do you think it is essential the top right screw in the connector shield is non-magnetic?
完成的
添加一条评论
添加你的答案
hari 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 2
总计 409
